I'm restructuring my business and moving from a regular office to a home office. I'm enclosing a section of my attached garage, about 70 sq ft, to be a small server room. 3 sides of the room are existing insulated walls with living space on the other side. The 4th wall will be built (with insulation) and will have the garage on the other side.
Since this room will have several servers in it running 24x7, it needs to have adequate cooling independent of the house, maybe even in the winter.
All the equipment will be using 600w continuously.
Is there a sizing calculator that takes watts into account?
Mini-split would be my first choice, but that's out because this situation may only be for a year, and there's not a good place to put the outdoor unit.
A window unit mounted in the garage wall would be cheap and easy. Aside from collecting the condensate (5 gal bucket) and getting rid of it (sump pump), what would be other potential problems with this?
A portable unit in the room has the same issue of having to vent with no window.
Any brilliant ideas?
Thanks.
Thanks.
