99 Merc Sable, 68K. AC seems to be cooling fine, but noticed other day that comp cycles about every 30 secs. Right now outside temp has been 85-90 at these times. ....... Any concern? Cycling normal?
I know I should check the pressure, but not so sure how reliable my 'shade tree' gauge is. ...... And also too lazy, if I can get out of it via an answer here.
· Banned
it will cycle every 10 seconds if your low on fluid. after a recharge - 30 seconds might be typical
if your low on fluid the "cooling power" will be low - and usually means "leaky seals" (cheap little seals at every joint that keep the refigerant "in")
