Hi guys,
I have a new central heating/cooling system installed and seem to have an issue here.
Over the winter I had no problems. Everything functioned properly.
Today I went to turn the A/C on and every 5 minutes the condenser turns off while the blower continues to blow air. Also the thermostat is still set to cool as it is far off its desired temp.
The only test I have done so far is check the voltage on the thermostat wire at the A/C and it is 24V. However, when the A/C condenser turns off it goes to 0V which leads me to believe the problem is at furnace/thermostat? If it was 24V the entire time I would think it may have something to do with the contactor or capacitor but if its showing zero volts it makes sense it is not functioning.
Also after 5 minutes it just automatically starts up again. It goes like this back and fourth non stop. Not sure what could be going on.
Any help?
Thanks!!
Any help?
Thanks!!
