The venting basically negates the insulation and certainly the necessity for 4" of ISO at a minimum. You usually run one of the other and not both.
So the vents eliminate the value of my insulation? And, do you think 2" would be adequate instead of 4" insulation? I asked the roofer about whether venting was necessary because previously on the flat roof the insulation was added and the roofer who did it could not stop the leaks and concluded it was condensation (I'm not sure about his diagnosis).The venting basically negates the insulation and certainly the necessity for 4" of ISO at a minimum. You usually run one of the other and not both.
i may want to purchase the home.if you mom is 89 years old.i might be inclined to go with the cheapest system properly installed depending on a few variables.
A couple rhetorical questions for you to ponder...no answers needed here.
How much equity is in the house?
What happens to the house when your mom dies?
If the house will be sold after your mom passes then i would more go with a less expensive product. If you or a loved one will move in then maybe more expensive makes sense.
I don't mean to sound morbid but at 89 your mom probably won't live another 10 years.
Venting would certainly lessen the necessity of insulation. At that point, if properly vented, the insulation is just a recovery/leveling board.So the vents eliminate the value of my insulation? And, do you think 2" would be adequate instead of 4" insulation? I asked the roofer about whether venting was necessary because previously on the flat roof the insulation was added and the roofer who did it could not stop the leaks and concluded it was condensation (I'm not sure about his diagnosis).
When I was last active some manufacturers were going from cutting checks to handing out vouchers for the shingles. So essentially forcing you to buy their product at a 10% discount......buy 9 get one free.So if the material fails at 18 years and it's a 20 year warranty shingle, the manufacturer will pay you 10% of the cost of replacement shingles. The other 80% and the labor are your responsibility
