Hello,
We have an existing 6’ wood fence with 4x4” posts all rotting away and needs to be replaced. It is straight and about 100’ long. Our neighbors have agreed to pay half for a similar replacement fence. However, we would like to pay the difference to have the new fence be 8’ tall, and the neighbors are ok with this. (I understand this is too tall to meet code and worst case we would have to cut off 2’ if some other neighbor complained.)
The fence posts are currently on “our side” and we are fine with that. For durability, we would like to go with metal posts, use standard 6’ wood slats and add a 2’ of lattice on top of that (built in a 2x4 frame for stability).
In addition, we do not want to see the fence/posts (over time), so we want to plant a Ivy (or some climbing vine) on or side, but rather than it integrating/climbing on to the wood boards (which eventually rot and have to be replaced), the idea I had was to attach rigid cattle panels to the metal posts (like https://www.homedepot.com/p/16-ft-4-Gauge-Cattle-Panels-33150739/202820268 ), and let the Ivy grow onto it and the metal posts/cattle panels/Ivy should never have to be replaced even if the wood boards rot on the other side.
We would start with a panel from the ground up to the height of a panel, 4', then after the Ivy grows up to 4', add another 4' horizontal section, eventually covering our entire side of the fence. The panels would be attached to the outside of the posts on our side, thus creating a gap between the wood fence planks and the metal panel of about 4"?
The question is:
1) Is this a good idea to create a lasting green ‘wall’ on our side?
2) If so, would 2 3/8” metal posts work (at 8’ above ground and 3’ under?) and at what gauge to support that height/load? And would you recommend keeping the posts 8’ apart on going closer to 6’ apart?
(As far as location: I’m in northern CA, a typical sub division, lots of mature large trees around, not much, no real “unusually gusty winds” come through.)
Thanks!
The question is:
Thanks!
