I'm running some 8/2 NM-B to a new pullout disconnect about 35' from my panel. My most direct route is definitely through the crawlspace. First question is does 8/2 qualify as a large enough cable to run on the bottom of joists or does it fall into the same category as 12/2 and require running boards or bored holes in joists? Second question is what size THHN green ground wire should I use in conduit from disconnect to heat pump along side the two 8 gauge THHN hots? Thanks
