Go with 16mm² { #6 AWG } that will handle fine for that distance however there is the other item may get your attetion is the type of cable if you going to bury it from the house to the spa panel or interruptor panel and I Know in USA you can not have bare grounding conductor but not sure if the Canada do follow it. { I know France the SWA is allowed but couple other cable is limited unless it run in conduit then use THHN/THWN conductors this is the only legit way }
So please state your location if you are in USA or Canada so we can able post the correct regulations to follow it.
Merci,
Marc
