1 - 10 of 10 Posts
Retired Moderator
Duh, Let me guess----5" thick jumbo 'flag stone' dry laid- If I guessed right use lime stone screenings.
Sometimes called 'limestone fines'.
Let me know if I guessed right.---Mike---
lol yea ok im laying around 5x8' pieces of 5'' thick jumbo flag all saw cut dry lay thinking of mortar joints but living in canada with the frost it would prob not work and they dont realy recomend poly sand for this application. any ideas?
Retired Moderator
Use lime stone screenings --sometimes called limestone 'fines'.
It's mostly powder and tiny chips---packs well and is less likely to was out than sand.
You will need to 'dress' it every year ,but it's the standard method.---Mike---
Retired Moderator
You are better off using the screenings without a bonding agent.
The bonding agent will cause the screenings to be like a mortar and will break up in chunks after a winter of freezing and thawing.
Just plan on adding a top coat with a broom once a year.
1 - 10 of 10 Posts
