1 - 7 of 7 Posts
I am running a 125 amp sub off my main panel and have used 4/0 AL, however, I am now having issues with the wire not fitting into the lugs in the 125 amp panel. I have not been able to find replacement lugs, so am looking for advice.
One electrician I talked to said to "trim" them down to fit. Now, this makes sense in the fact that I have overkill in my wire, but I dont think this is the best solution, but maybe it is...
Any help would be appreciated!
Cheers!
DIYer
This is coming off a breaker in your main panel? You found a breaker that fit 4/0 but not a main lug panel?
If the run is short, 2/0 copper is about the same amount of overkill, you could use that instead. heh
Licensed Electrical Cont.
I'm just wondering what "friend" told you to run 4/0 ?????
I don't have a solution other than using crimp on reducers, which for a DIYer is not really an option unless you want to rent a crimper.
UAW SKILLED TRADES
How much of this 4/0 did you have to use? If the distance is short I would uninstall it and install a feeder that will serve your calculated load or 125 amps which ever you choose. Like gigs I would like to know how you connected at the main panel....it wasn't to a branch breaker so maybe feed thru lugs or sub-feed lugs??
Discussion Starter #5
4/0 wire
Yes, the 4/0 fit the 125 amp breaker in the main panel, but does not fit the supplied lugs in the 125 amp sub panel...they are sized for 2/0 copper it appears.
The run is about 50 feet, however, I am trying to avoid replacing the wire as I had enough fun wrestling it in already.
Crimp on reducers? That would be great, as I have a crimp tool. Any idea where to get them?
Thanks again,
Discussion Starter #6
4/0 issue resolved
Thanks everyone for your help. I decided to just order the correct wire, so all issues are resolved.
Thanks again,
Starpole:thumbup:
1 - 7 of 7 Posts
