1 - 20 of 22 Posts
:thumbsup: I am installing a 30amp RV outlet 100ft from my main panel using 3 #8 wire
my question is I want put a regular 15 amp outlet that would feed from
30 amp outlet can i just pigtail #8 wire with #12 wire.
· Licensed Electrical Cont.
NO! You cannot have a 15 or 20 amp receptacle on this 30A circuit.
They do sell RV boxes with separate breakers for the 30 and 15 amp receptacles that are basically small sub-panels with built-in receptacles.
I'll try and find a link for you.
The 30A RV receptacle does NOT have to be GFI protected. In fact, good luck finding a single-pole 30 GFI breaker.
The other alternative, and likely cheaper, is to run two separate circuits out to the pedestal. One 30A/120v and one 15 or 20A/120v. You can share one #10 ground.
Discussion Starter · #6 ·
Thanks petey for the usefull info the all in one box seems the way to go
but if i decide to do 5 wires in 1 condiut 3 #8 and 2 #12 whats the proper
size of conduit? Im using #8 due to distance from the main panel 100ft and might have some voltage drop off and also the #8 wire was free from a
friend.
I would use 1". You can get away with 3/4" but it's really not worth it. 1" will make things much easier.
Same
That's the same thing 300 ZX stated but in much less wording.
He also got the gfi receptacle in there with much less wording.
No sir, you did not offend me. Don't flatter yourself. :laughing:
And don't be jealous that Yoyizit is on my side. He is a good guy.
Happy
Mr. Sultan, you're not a happy camper. But. . .that is not the fault of this forum.
Matter of fact I am in the process of packing last minute items for the week end get away, my trailer and camping.
Good job Mr. Yoyotits:laughing::laughing::laughing::laughing::laughing::laughing:
1 - 20 of 22 Posts
