I have 2 - 150 Amp Wads Worth Breaker panels. I'm getting ready to install a spa with a 60 AMP breaker, to be feed to a 60 Amp GFCI outdoor disconnect. Here is my problem, the Wads Worth breakers are not readily available and expensive, also the previous owner made some connections in the panel that needs to be cleaned up.
I decided to replace both panels with Square D OH series. The 150 Amp panels are more money than the 200 Amp Panels. Since I will have to use new feeder wires from the meter, should I just upgrade to 2 - 200 Amp Panels.
I work on robotics as a profession so I'm comfortable pulling the meter.
