· Administrator
30 lb. felt weighs 30 lbs per square. 15 lb weighs 15 lbs per square. That’s was back in the day, like with everything else getting scaled back it’s now called #30 felt which is about the same as what 15 lb. used to be.
I’m not even sure if 30 lb. is still available.
· Shut in w/o Home
so if I two estimates and one says #30 and the other says 30lb, they aren't the same? If I understand you correctly? Thanks.
It's now #30 felt. Some people still call it 30#. My local options are #15 or #30. A 2 sq roll used to weigh 60lbs. It doesn't anymore.
I mostly use synthetic underlayments. A lot of people call them synthetic "felt". There's no resemblance to felt although it serves the same purpose.
