1 - 8 of 8 Posts
I cannot find a diagram for my setup
power-(12-2)-light-(12-2)-switch-(12-3)-switch-(12-2)-light
both switches are 3-ways
everything works, but the first light is dim. And when i take the bulb out of the first light, the second light dims.
flipping slumlord
the first light is dim...
Assuming this is the ONLY place in the house this is happening:
check the voltage and all connections.
odds are something is loose
(and probably where everything ties together in that first light fixture JB)
A "Handy Husband"
Can not work the way you describe- you have no way to get the neutral to the last light.
Discussion Starter #4
that is what i read. Someone explained that i would need another 12-2 wire connecting both lights:
"=" means 14/3 and "-" means 14/2.
Power-L1-S1=S2, and L1-L2
but i did not understand how to do this
Master Electrician
12/2 to switch 12/3 to switch 12/2 to light 12/2 to light.
Box 1 switch box
Connect whites together
Connect black from 2 wire to common screw
Connect red and black from 3 wire to traveller screws.
Box 2 switch box
Connect whites together.
Box 3 light one
Connect blacks and pigtail out to light. Connect whites and pigtail out to light.
Box 4 light two connect black and white to light.
If you add a wire between the lights to carry the fixture you'll be only useing the white from the cable. Legalities aside as an electrician I would frown on running your neutral a seperate run from its power. We aren't allowed to run a neutral in a different conduit from its hot. Not sure offhand how it works for romex runs. Someone more well versed in the nec can answer that I'm sure.
Discussion Starter #6
so should i just bypass the first light with the incoming power so my sequence becomes
power-switch-switch-light-light
so the 2nd light is only connected to the 1st light
1 - 8 of 8 Posts
