21 - 22 of 22 Posts
Take out the switch you want to remove. Detach all wires to it but recall which wire goes to which terminal.
Take the wire that went to the common terminal---the black screw.
Connect this wire with either one of the other wires from the switch.
Put a wire nut on the remaining wire.
The other switch will now function as a single pole switch.
The colors of the wires in the following diagrams may not correspond to your setup. Ground is not shown for clarity.
Discussion Starter #22
Hammerlane is a Genius
Hammerlane you are a ...Genius! Thanks so much for the diagram. Everything is working great. Thanks for everything! :)
21 - 22 of 22 Posts
