Hello all, hoping someone can help. My fridge isn't cooling anymore, fridge or freezer. Fan still runs tho. I bought a 3 in 1 hard start to see if that will make it run. I didn't want to buy the 40 to 50 dollar relay incase it wasn't the relay that went bad, but I'm pretty sure its the culprit. The relay looked like it burnt up inside when I broke it open.
I did the continuity tests on the compressor and they all came back good. So that test is done. I want to hook it up and use its own power source. The reason is I don't want to cut the existing wires to the compressor, incase I do buy the relay. I would like to keep OEM parts in there if I get it running.
So, my question is, can I take power straight from an outlet and hook into the 3 in 1? I would take an old plug in cord and hook it up to the 3 in 1.
Thank you,
Thank you,
