I have a 3 gang electrical box in my home with 3 toggle switches. The home was built in 1980 and it should've been wired by licensed electricians. I'm the only owner of this house since it was built and this switch box was never modified. This is how crowded the box currently is with those 3 switches:
I want to add one more 14/2. I want to convert that switched outlet to full time power. And then with the new 14/2, I want to repurpose that single pole switch to control new LED wafer lights in the ceiling of a living room. But those splices are already seemingly maxed out. Adding 3 more conductors will make them even worse.
I listed the inside dimensions of that 3 gang box. I glanced at a NEC table for electrical box fill maximums but I got confused real fast. My questions are:
1) Does anyone know the NEC code on how many wires that box is allowed to have and can I even add another 14/2 run?
2) Regardless - what are the proper techniques for splicing such a large amount of 14 gauge wires? Currently there are 10 ground wires spliced together if you include the 3 pigtails going to the switches. There are at least 5 neutrals twisted together in a big red wire nut. There are at least 5 hots twisted together in a big red wire nut. I haven't been able to open everything up and diagram what's going on - but the point is this is a lot of conductors that need splicing and 3 more would be added.
I noticed from the limited vision I had in the box that all those grounds were using crimp connectors and it seemed to be branched into 2 different crimps with a pigtail. But the hots and neutrals were both in big red wire nuts and they seem maxed out. So please let me know your opinions on how to splice such large amounts of wire together (even if I can't add another 14/2 run to that box. I'd just like to know how electricians splice that many wires together).
Even though my 3 gang box is from 1980, I see they still have new work 3 gang boxes today with 12 wire entrance knockouts. I understand that is for convenience of where you want your wires to land - not necessarily that you are allowed to send 12 runs into a 3 gang box - so that goes back to my question #1
Thanks for your time!
