How bad is the slope?---You may wish to pull out that pocket door before you begin tiling---
If your calculations are off that door may end up trapped,requiring demolition of the new floor to correct the problem.
Self leveling compound can correct a minor slope----major?? It's easier to sister in new joists --
Floor structure for tile--a nut shell---Joists strong enough not to flex and break tiles.
3/4" exterior glued plywood.
1/4" backer board set in thinset and nailed or screwed--(thinset fills voids so backer won't flex when stepped on)
Then Self leveling compound with its primer if needed.
then Tiles set with modified thinset----
