Anyone know where I can find wood screws that are 3/4" long that are stainless or ACQ rated?
I have to fasten a bunch of pipes (with copper pipe straps) onto 1x2 pressure treated furring strips.
The 1x strips are 3/4" thick, so I need 3/4" long wood screws.
The 1x strips sits over concrete block walls, hence they are pressure treated. I understand one must use ACQ rated or stainless screws or else they would corrode very quickly with the chemicals they use to treat lumber today.
I looked at local home centers and yes they have ACQ rated screws but nothing that's 3/4" in length. I found 3/4" screws but they are zinc.
Thoughts?
Why not just use copper nails?
Discussion Starter #3
Copper nails, I am not sure Joe. I think the pipes vibration would eventually tease the nails back out. I guess I feel more comfortable with screws.
Both Lows and Home depot have 3/4" stainless steel screws with larger heads for attaching vinyl lattis. Look over where the lattis is.
Master General ReEngineer
Ayuh,... 'n in my local stores, they have SSteel sheet-metal screws which will do the job needed...
1/2", 'n up, length, from #6s to I think #14s....
