How do you drill holes, thru fire stops/headers from the bsmt or attic, when they are 10 ft away in the walls?
I need to run a water line from the bsmt, up to my attic. The area around the soil pipe is too crowded, and the laundry chute/chimney is also blocked.
So I need to make a new run up.
Any idea's on how this is done?
thanks all !!
-Mark
Just drill the holes through the fire stops and put a sleeve in.
When you have completed the job buy fire stop caulking and just caulk around the pipes real good. The caulking is approved at high temps.
