Sorry, that's actually a "catio", albeit a poor rendering.You can attach it there if you like. But do you really want to lose 3 windows? Why not a free standing shed?
No, windows 10 has decided i can no longer use an old blackberry phone as a camera.Thank you @Nealtw . Any chance at seeing pics of your flashing/roof interaction?
Here's my house while being framed....
My band lands right on the top plate, pretty much centered on them. What material is your belly band, and did you use fasteners long enough to get into that rim joist, or just let the band hold the brackets for your rafters?
Here's the truss going up on the roof.....Is the gable a wall or a gable truss?
So you can see if you lag to that there is not much to hold the bottom of the gable from pulling away.Here's the truss going up on the roof.....
Our band board is a painted 2x10 fir rough texture.Thank you @Nealtw . Any chance at seeing pics of your flashing/roof interaction?
Any particular reason why your sheeting is installed vertical?Thank you @Nealtw. Any chance at seeing pics of your flashing/roof interaction?
It seems to be a thing down there.Any particular reason why your sheeting is installed vertical?
Hmmmm...due to the strength axis in ply and osb they should always be horizontal with staggered joints.It seems to be a thing down there.
Their walls are higher than ours too, so not much to nail to the top plate. We get away with small walls like beside the garage door but never on one with 8 ft studs in it.Hmmmm...due to the strength axis in ply and osb they should always be horizontal with staggered joints.
Would be ripping it off if the inspector had anything to do with it....lol
Unless it was blocked on the inside for board/batten etc...
Hmmm, Maybe a little lower so you can tap into the top plates with a ledger.Crap, I don't have access to that end of the attic. The combination of scissor truss, insulation, and ducting is pretty much impassable.
So would Plan B be to get aggressive with cross bracing on the new structure to reduce swaying and twisting in high winds?
If I did that, what would you recommend for flashing? Wonder if I could find the right dimension to tuck under the flashing above the belly band and reach down to the ledger.Hmmm, Maybe a little lower so you can tap into the top plates with a ledger.
If you can't find one you have a sheet metal shop make what you need.If I did that, what would you recommend for flashing? Wonder if I could find the right dimension to tuck under the flashing above the belly band and reach down to the ledger.
I really appreciate your advice @Nealtw, thank you!If you can't find one you have a sheet metal shop make what you need.
Or find one first and let that help dictate the elevation.
