1 - 20 of 21 Posts
I've googled and can't find the answer. Likely been answered a zillion times.
Is a 2x4 spanning a 24" space stronger in the midpoint placed on its edge or flat?
I'm guessing on edge but wonder by how much.
I'm installing a backup safety cable for a storage rack and want to use an eye bolt into a 2x4 running across ceiling joists. It would be easier to install the eye bolt into the flat orientation than on edge (using a threaded eye bolt with washer and nut, not screw thread).
TIA
retired painter
2xs are always stronger on edge, consider how a header is constructed. Obviously it's easier to drill thru the flat side. You might consider using both flat and on edge - connected together.
Remodel and New Build GC
Unqustionably as noted above.....
Sometimes when an application requires and you have to use a 2X with its flat side taking the load (force at 90 degrees).... we use a strongback........which is just another 2X attached to the flat side on its edge to give it greater streangth.... hence the idea of strong-backing.
Mathematically, the strength is based on the Square of the depth of the piece of wood.
On the flat, the number is 1.5 inches squared. (1.5 x 1.5) = 2.25
On edge, the number is 3.5 inches squared. (3.5 x 3.5) = 12.25
As you can see, on edge is stronger.
Actually, i need to correct the above posting.
Forgot to consider the difference widths, so multiply each of the above values by the width of the materials.
(2.25 x 3.5) = 7.875
(12.25 x 1.5) = 18.375
That's better. The original calculation would only be valid with the widths being the same. Sorry for the lack of consideration for the width in the original posting.
Thank you all!
I've decided to forego wood and use a 3/4" square metal tube; will be more than strong enough and I won't have to find an eye bolt of the right length to go through a 2x4 on edge and my ceiling joist.
If he used a 1/16" to a 1/8" in. thick wall 26 " long 3/4" x 3/4" steel tubing, I bet it will not hold as much weight over the long haul as a edge up...2"x4" will. JMO
Discussion Starter · #10 · (Edited)
Where do I get the information on the strength of 2 x 4 wood on edge (a Daniel question)?
This will essentially be a point load since the eye bolt goes through the narrow edge and terminates on the top edge of the board. I would think metal might be stronger in this situation especially as the eye bolt will naturally weaken the wood as a hole needs to be drilled through the narrow edge for the bolt to exit for the nut: View attachment 505346
The gold blocks are 2" x 4" truss bottoms.
Thank you all!
Might look into a piece of "unistrut". It's designed to do exactly what you're looking for--provide support for a load across a span. The spring nuts available for it are threaded in 3/8" allowing you to use shouldered eye bolts or all thread with female threaded eyes and jam nuts to hold it all together.
Sent from my mobile look-at device
Discussion Starter · #14 ·
Both ideas are good; I'm still leaning to 3/4" sq tubing from HD; a bit less labor and less heavy stuff to carry to the spot in the garage attic stepping on the joists (I hate it up there).
Thanks for everyone's good ideas!
An application question to this calculation. I want to install an extending TV mount (extends out 27", single stud installation, 2 lag screws) on a wall that was built over a door frame using 2x4s turned sideways — i.e., screwing into the 3.5" side rather than the 1.5" edge. The sheetrock is 1/2" and there's about 1" of air space behind the 2x4. The TV itself is only 26#. If I use the included 75mm (@3") lag screws, with the sideways stud hold the TV securely?
To be accurate --- the 2x4 is the same strength regardless of how you orient it, just that it will be seeing a lower maximum bending stress if oriented on edge, when loaded as you described.
I realize this is an old thread, but in the interest of providing accurate information, I'll dive in for a minute.
The bending strength (what us engineers call the section modulus=S) of a 2x4 (or any other rectangular shape) is width X height squared / 6 (for orientation - that's for vertical loading). For a 2x4 oriented edgewise S=1.5x3.5x3.5/6=3.0625 inches cubed; oriented flat, S=3.5x1.5x1.5/6=1.31 inches cubed.
Shear strength is about the same in either orientation.
Stiffness is similar, but it's width x height cubed /12. That's why a 2x6 is nearly 4 times stiffer than a 2x4, spanning the same distance.
Also, torque is force x distance, both in applied loading and resistance, so quatsch is correct for the 26 lbs at 27". To finish the loading calc, the tension on the fastener is the torque / the distance from the fastener to the edge of the base plate.
1 - 20 of 21 Posts
