Hi all, I'm about to install a replacement whole house humidifier on my forced air heating and I had a question about the power supply. The humidifier is a Honeywell HE240 and it comes with a plugin 24V transformer (also it states 0.416A and 10VA, so sure if one of those is the amps?). The thing is I know the last humidifier was wired to a transformer from inside the furnace which is listed on it's housing as a 25V, however in measuring it seems more like 27). My question is can I just use this instead as it would be a much nicer install that way. The old humidifier was a drum/foam element job, whereas this one is the mesh with water system (not sure the name for that; "bypass"?). So the old load was a motor and the new is a solenoid. But in my mind I'm thinking that likely this would be a standard kind of setup; power consumption wise, however I really wanted to consult before recklessly hooking up to the old supply. Thanks.
