Hi,
I have a Cat excavator and I want to put a radio in it. The machine runs off 24vDC and I tested off the switch and it is also 24vDC. I was looking at some voltage converters (5 amp). But I was wondering what others would recommend on what I could do. Thanks.
· Semi-Pro Electro-Geek
The converter is a great solution and probably the best idea. However, a simpler way is to just connect the radio to one of the excavator's two batteries. 24V heavy equipment uses two 12V (or sometimes four 6V) batteries in series. If you tap off of the first battery, you get 12V. This results in uneven load between the two batteries, thus slightly overcharging the other battery - but if the load is small (like a stock car stereo) then this will not cause any problems. Be sure to use an appropriately sized fuse placed as close to the battery terminal as possible.
