Just powered up 2010 Jacuzzi J335 hot tub after 9 months off. Got FL1 error (everything else worked (jets, lights, etc)), so turned off breaker several times while troubleshooting. Now control panel remains dark, no signs of life.
Opened up hot tub electrical service box, and used multimeter to test 3 wire 240v at Terminal Block. Red(1) + Gnd(3) = 115v; Black(2) + Gnd(3) = 115v. So far, so good. To test for 240v, I touch probes to both hot legs (Red(1) and Black(2)) simultaneously. Should get 230v, but instead get weird variable 2-12v readings. I do same test on circuit board at Transformer and Circ Pump (16/17), and get same results.
Am I doing something wrong in my test? Is my meter malfunctioning? Or is this some weird power problem coming into the tub?
I probably have dead Circ Pump (original FL1 error), and maybe dead Control Panel or Circuit Board now. But I want to understand if my power is OK 1st before I start buying parts for other fixes.
Thoughts?
Thoughts?
