Hey all,
So long story short I use a 30a 240V outlet (GFCI protected) to brew beer in my basement using electric heating elements and solid state relays to turn the elements on/off based on a signal from a PID Controller. I built my own box to hold the relays and turn each element on/off.
The GFCI protected 30a 240V line is hard wired to a point in my basement, and from there I plug in a portable control box that allows me to switch which elements are running and turn them on and off. The box plugs into the wall outlet, and has two outlets on it that the electrical elements get plugged in to.
My question is, from all that i have read these 30a 240v lines need to generally be run for a dedicated circuit, what I would like to do (if it is within code/legal) is install a more permanent box that holds the relays in a side room adjacent to my brew room, and run the appropriate wire and outlets to my brew space to save the hassle of plugging in the box i mentioned. Is that allowed?
Thanks for any insight you can share regarding this question!
