1 - 7 of 7 Posts
I would like to run 240v to my garage. The plan is to install a sub-panel, inside the house where the A/C #8 wire exits.
Will a sub-panel support the A/C compressor and 240v to the garage?
Note: Currently the detached garage is fed by a 30A fuse (120v), ran through buried conduit.
http://imgur.com/D3HVRFq - Service Panel Make/Type
http://imgur.com/wkNU8hy - Service Panel Wiring
P.S. I did not think that I could justify starting a new thread when, seemingly, such a similar one already existed. I apologize for any inconvenience.
Please do start a new thread for the benefit of the Original poster, and others.
Administrator
Made this its own thread. So no confuses you and the OP if the OP has more questions.
Reactions: dasbinder
Administrator
Already done.
Super Moderator
Two problems, the A/C needs its own circuit and there is no neutral in the circuit either. You are going to need to run a new circuit.
Discussion Starter #7
I updated the image from inside the panel ... http://imgur.com/IL4EAqA
My fuse diagram from when the AC was added, shows this 25A circuit for A/C and Furnace. The 'Range' used to be a an electric dryer, before it was used for the A/C ... http://imgur.com/9sZfgci
1 - 7 of 7 Posts
