Hey gang, I have a quick question for you.
I should state that I am an accomplished handyman and have done quite alot of construction and electrical work that stood up to inspection. This time i have a unique situation and need some advice.
I currently have a 240 volt circuit that has a continuos load of 18 amps for about 14 hours a day (kiln). I ran 10 gauge wire for this circuit. I am planning on installing a split air conditioner as my studio is quite hot. It pulls a maximum of 8 amps (240) I dont have space in my panel for another double pole breaker (no I am not exceeding the overall load rating) so I wanted to run a 12/2 line to the new air conditioner (20') and run it to the same breaker. Is this going to cause a problem? The breaker is rated for 40 amps.
I seem to recall reading about 5 years ago that I read something about having to use the same gauge wires when they both connect to one breaker.
Thanks!
Thanks!
