BigAlec
Hi All
I have just bought a 240V radial arm saw that has a 3 Prong plug on it,
I want to run it on 240V and not convert it down to 120V
I already have a 240V receptacle on the wall but it is a 4 prong round plug (it was for a wood planer)
I have bought a 3 prong ( ground pin and 2 horizontal pins) socket to swap with the 4 pin (existing socket)
How does one connect the 4 wires (red, black, white and green) from the main supply to the 3 pins in the socket ( two unmarked and a ground pin)
thank you in advance
Alec
Super Moderator
provided the amp rating of the new receptacle is proper for the breaker you would conenct the red and black to the X and Y terminals. The white is capped and not used. Ther green or bare wire goes to the ground pin.
