Dears,
I have issue in my apartments.... the voltage is 170..
I check all the building is the same and the adjustment building is the same .
this happen only during the local generator shift (about 8 h per day) witch is about 500 m far from our building.it is a 100 KVA 3 phase generator..
when we complain with the generator company they told that "and I measure by my self" the voltage in the generator output is 230.. and the building which is Adjacent to them have 220 v...
he call the electrician but his answer that there is no solution because you are far from the generator :surprise: and you have to buy a voltage regulator..
most of the devices and lights in my apartment is not working..
can you please suggest a solution because I think the fault is from the local generator company and he should correct some thing...
with best regard
with best regard
