I have a appliance that is 220v, in my experance to get 220v you need 2 110v legs but this device has L-pole N-pole and GND-pole if you put 2 110v legs on the L-pole you still only get 110v not 220v can anyone solve mo problem
Post pictures of the name plate and termination connections.I have a appliance that is 220v, in my experance to get 220v you need 2 110v legs but this device has L-pole N-pole and GND-pole if you put 2 110v legs on the L-pole you still only get 110v not 220v can anyone solve mo problem
Are you asking in US Residential systems? You have split-phase power (V+ and V-) with a reference voltage (V0) in the middle. It is basically sine waves mirrored across the time axis (so in the instant when the voltage on one leg is 30 volts above "zero" (called neutral, ground or V0), the voltage on the other leg is 30 volts below zero.)Two legs are 180 degrees out of phase is how come they do not cancel each other out.
As Jump-start pointed out, power in the US is 60Hz. I believe some appliances can fail to function, can function oddly, can be less efficient, or can even be dangerous when operated at 50Hz; for others it does not matter. You need to figure out if your particular appliance can accept 60Hz power. The manufacturer may know, or there may be a circuit diagram you can use to figure it out.input voltage: AC220V 50HZ
That explains it. L and N are the 240 volts.The item is from China and made for there grid
As others have asked "what is the appliance"?input voltage: AC220V 50HZ
Frequency should not be an issue with a heater.the appliance is a heater pot for melting solder
Since this is a heating appliance designed to "Plug in" in a country that (officially) uses 230 V AC as their domestic supply, it is unlikely that the current drawn on 230 V will exceed 10 A. (The "name-plate" should indicate this and the small devices that I find listed on Ebay are rated at only 150 W - 652 mA)the appliance is a heater pot for melting solder
