I'm just exploring now for my sister. It's dated condo building, all concrete. There is no chance of venting to outside and the existing wiring can't be rewired in a realistic sense, budget and not wanting a lot of tearing into the wall/ceiling.
It is electric range/oven/microwave, 220v, and single white wire behind it (before color coding) and 50 amp breaker. All functions are built into the unit, no chance of separating, no outlet, microwave dead.
220v range/oven is available. Even 220v microwave, although I don't know yet if these are even sold in usa. I don't know what amps they will need.
So only source of power is that single cable which I assume should be 10 gauge 3 wire cable. I assume they are black, red and a ground. I think existing 220v circuit does not have to be rewired for neutral.
Question 1: can I splice 220v cable? The existing cable into a box, then 2 pig tails, one for the range and another for microwave?
Question 2: am I correct to assume that these appliances will work without the neutral?
