1 - 7 of 7 Posts
Hi,
Just moved into an apartment in the Caribbean and it is wired with European outlets and wiring.
I have a simple light fixture ( non dimming single phase) but the wires are White, Black and Green.
Which wires should I match up with the ones coming out of the box on the ceiling.
The wire colours coming out of the ceiling are Black, Blue and Green/Yellow. I have access to 220V bulbs.
Thanks a bunch!
Dew
Make sure your fixture is rated for 220, too.
It's highly unlikely to be rated for the higher voltage. Conversely most fixtures built/sold in Europe are not rated for use here. For most incandescent fixtures just changing the bulbs is all you need to do.
Voltage rating is important for lamps contains fluorescent ballasts or led drivers
Going from 120 to 240v, your amperage is cut in half, so if anything the wiring is slightly oversized
While the fixtures are not listed for use, from a practical point I would consider the use of a North American listed fixture elsewhere, or a western europeon fixture used here, far safer than many DIY or Artisan lamps that some people make/buy here.
Discussion Starter · #6 ·
I noticed that the wire from the ceiling (220) appears to be a bit thicker( eg. Solid) when compared to that of the fixture (eg. Strands). I reckon as long as I use 220 V bulbs, i'll be fine with the fixture.
What do you guys think?
Dew
That is normal. The ceiling wires are sized by the circuit breaker, the fixture wires are sized for the fixture,
If you pulled the fixture out of your previous house in the US you would have #14 or 12 solid (romex) in the ceiling with #16 or 18 stranded in the fixture.
1 - 7 of 7 Posts
