Hi,
I have a 200 amp service in my house. I have 100 amps servicing my house and 100 amps feeding a panel out in an attached garage.
OK - I just put up a detached garage (about 30 feet from the main service box on the outside of the house) and want to feed it with 100 Amps minimum.
What are my options ? (I'm not electrically experienced). I was thinking I might be able to have a 400 amp service put in and up to the house and then have the 400 amp box feed the existing 200 amp box and then take the other "new 200 amps" and feed the new detached garage?
Any help/suggestions welcomed !
Thanks,
Chris
i would contact a few licensed electrical contractors in your area to quote you on a new service installation. you would be wise to listen and learn from these people. one might give you a good tip. another something else. what you need will be directly related to your load requirements. in essence, what are you asking your new garage to do? welder? air conditioner? possible future expansion? any 220 v motors? expert advice will be very valuable here. also, your electric utility company will send a rep out to talk with you and your needs too.
Just feed the new subpanel with a 100 amp breaker, and install a 100 amp subpanel.
Not an issue, unless you are planning to set up a welding shop, or shop with high power demand.
Thanks for posting up and giving me some direction.
The garage will have a car lift, welder, air compressor, Milling machine, 2 window AC units... basic lights, and other smaller electric stuff. I probably should start creating a list of equipment/power usage and start there.
