Hello everyone. I am putting in a 200 amp Square D panel. The panel is in a utility room, and there is a main shutoff on the back of the house. I have a couple of questions about the cables that to the panel from that main shutoff.
1. My existing service cables are 2/0 aluminum. I read that a 200 amp panel should get either 2/0 copper or 4/0 aluminum. I find that kind of confusing, because isn't copper a better conductor than aluminum? And isn't 2/0 bigger than 4/0? I'm confused why a better conductor would need the bigger cable. But I suppose my bigger question is, is 4/0 aluminum a minimum standard, and would 2/0 aluminum be ok?
2. I noticed on my panel that the neutral lug is slightly smaller than the two hot lugs. Does this mean the neutral cable ought to be smaller as well? If not, why is it smaller?
The panel is a Square D QO plug on neutral load center.
Thank you very much for any thoughts. I really appreciate it.
