We are building our own house. We had the local coop install the new power service to the site. We have OH line to a pole, then UG line to another pole where there's a green box next to the pole and a meter.
We are going to go with electric heat for the basement using an electric boiler for radiant, and most likely an electric furnace for the upstairs. The coop will install a second meter to use exclusively for the heat, but I'm not sure how that is set up.
We're not electricians, but we will be running all of our electric wires ourselves, including the ones between the meter and the house. We can save the labor cost this way, and a qualified electrician will actually hook up the wires to the panel, and the panel to the meter, and do an inspection of our work.
I asked the coop but have no answer yet if we have 200 Amp or 400 Amp service, and I can't remember what they installed, and it just occurred to me that 200 Amp might not be enough if we're running electric heat. We do not know what our electrical loads will be, but being out in a farm there are welding and tool shop operations a lot, and I'd have to overload in winter when the heat is on. We also don't know the rating of the heating equipment since we're probably not buying that for a year or two.
These are probably dumb questions/statements but... how would we decide if 200 Amp is enough? Should we have two separate 200 Amp service panels running each from the separate meters? I think 400Amp equipment is more expensive too. If we have one 400 Amp service, can that be split between two 200 Amp panels? I guess that might depend on how the coop sets up the two meters no? Are meters rated for 200 or 400 Amp services?
Also, I'd like to have a kill switch before the electric panels. Our current (very old) house has a fuse box between the meter and the rest of the farm, and it's nice when working outside to cut the power off. Could a kill switch be run so that electricity from both meters is shut off?
Thanks for any input.
