I recently bought a house with 2-wire throughout, 2-wire without grounding conductor. Home has a circuit breaker box, 100 amp service.
This is a brick ranch on a slab, with the electrical service grounded only to the plumbing.
I don't have an immediate need to replace all of the wiring in the house with updated electrical wiring. However, I think it makes good sense to do something before hooking up a room full of desktop computers.
Without knowing much, here is what I think I understand thus far (Confirmation of below is much appreciated, or argue me down! See also my questions, please.)
(1) I've been told that all I need to do is replace all the outlets with GFCI.
(a) Q: If there is no grounding conductor on a 2-wire, what is the risk of doing only this action in item 1 ?
(b) What about places which have a terminally active point, but no 'outlet' - such as an attic fan which is on the electrical circuit but which
doesn't have a receptacle outlet? What is the risk at those points?
(2) Obviously I could have someone fish the entire house and replace all wiring with new wiring, in addition. I would do solution item 1 and solution
item 2 together, in this case. But is there more that would also need to be done? What about behind the panel, meaning between the panel
and the outside meter, which I understand is also older wiring?
(c) What else should I be thinking of here, that I obviously do not understand or am not considering?
I really appreciate advice!
Tks.
Tks.
