Greetings all, long time lurker and first time asker
I bought a fixer upper of a house, and on to the electrical portion. Most of the house is a 2-wire system (no ground), and a previous owner replaced all 2-prong outlets with 3-prong outlets. He did so without actually grounding anything, that b-hole...
I've fixed most of it using GFCI outlets and even GFCI breakers in a few case when it was cheaper. IMHO, a GFCI would likely be safer than a ground in most fault situations, so I'm fine with that.
I'm trying to add a few outlets to the somewhat finished basement now. The wall I want to add outlets to isn't a stud wall, its just furring strips and wood paneling. So, I was planning on using conduit and handy boxes.
Metal conduit and boxes isn't an option without running new grounded romex from the panel, and it isn't an easy route. I'm considering using PVC conduit and boxes.
Finally, here's my question. If the conduit and boxes are nonmetallic, and I GFCI protect the outlets (or the breaker feeding them), can I get by without running new romex w/ground? I know that's fine for most outlets, but the fact that it is surface mounted on the wall and run through conduit makes me want to double check.
I'm very comfortable working on the electrical parts of the house, I have a PhD in electrical engineering. I just want to make sure that I'm compliant with code. I'm in IN if it makes a difference.
On a related note, anybody know where I can pick up a crap ton of 'no equipment ground' and 'GFCI protected' stickers?
Thanks for the help
Thanks for the help
