We have a new house (built last year) with an open floor plan. We have a 2-story living room and have recently installed a faux fireplace on the one wall. By faux fireplace, I mean we built a bump out, stoned it up to the ceiling and installed an electric fireplace. It's a little late now, but I am a little concerned about the weight of the wall. The structure we built, including the stone, weighs about 2,400 lbs. The wall it was built on is a load bearing wall with a steel beam under it and a steel column supporting the beam in the basement (and both ends of the beam are supported by the concrete foundation walls). The fireplace bump out is 6" deep and 87" wide so the wall spans 5-6 joists. Does anyone have any thoughts as to whether this load will be ok spanned over that many joists and directly above a load-bearing wall or should I seriously be considering having a structural engineer come out (it would be around $900 for that).
I've attached a picture of the nearly-complete fireplace so you can get an idea of what it looks like.
