I have a new 2 stage ASX180361a 18SEER 3 ton Amana AC unit, with a GMV950704C variable speed high efficiency furnace.
I am using a Honeywell TH8000 Series Programmable Thermostat.
If everthing is connected properlly, see below.
The question I have is how do you know if the AC unit is in the first or second stage of operation. Can you tell by using a clamp on amp meter while the unit starts up?
The installer said it needs to run for 20 minutes at a low temp setting. I set the ac for 65 and ran it for an hour. Current draw is 6 amps with the outside air at 88 degrees.
It started at 6 amps and stayed there.
Appreciate any help here.
