1 - 13 of 13 Posts
I'm wiring up a 208 volt air handler in my attic I'm interrupting the 12-3 coming in and putting a toggle switch for a means of disconnect does it have to be a two-pole switch or can I make it a single pole switch and splic through one of the other hots thank you?
If it's an "air conditioning disconnect" as required by Code, then you bet your bippy it has to be 2-pole. The whole point is to de-energize equipment so the air conditioner guy can stick his clumsy thumbs all over the works.
In fact, air conditioners are extra special in that they don't allow to put a locking device on the breaker instead of a line-of-sight switch. Most other loads do... I guess the A/C repairmen have a good lobby :)
As far as 12-3, nobody ever regretted running a neutral they didn't need, but precious few air conditioning units actually want the neutral. If your line of thinking is "A/C repairman's receptacle" you can't have a receptacle on a circuit with hardwired loads accounting for more than 50% of circuit ampacity. If your air conditioning unit's instructions allow for a cord-and-plug connection, I suppose you could put a NEMA 6-20 plug on it - a 12/3 MWBC could be wired with both a 6-20 and 5-20 receptacle on it.
Master Electrician
Should say “line “ and “load” on the back of the switch or on the box the switch came in.
Licensed electrician
The OP should have a DPST switch, not a 3way.
Reactions: joe-nwt
A "Handy Husband"
208 means you have 3 phase service at your house? Is the air handler single or 3 phase?
Sent from my moto g power using Tapatalk
Discussion Starter #9
The air handler is 208 single phase. Just looking for what color screws on what side the red/black line and load wires attach to. Ty
A "Handy Husband"
Use a $10 AC pull-out disconnect and interrupt both hots
Reactions: seharper
I didn't know they were that cheap shudder but rjniles has the right idea IMO.
2-pole switches rated for that kind of current are more money than that.
Not least, it looks like a disconnect, so the air conditioner service man will instantly recognize it as a disconnect, instead of complaining that your installation isn't compliant.
A "Handy Husband"
$9.25 at the Depot
Licenced Electrician
Typically the 2 black screws would be line and the 2 brass screws load. But in the absence of any markings for such, you should use an ohmmeter and verify.
1 - 13 of 13 Posts
