1 - 1 of 1 Posts
" Euro " electrician
Get three speed dehummer verison the Lutron should have this as stock item otherwise I used Pass et Seymour they are good one as well and there are few other good brand you can use but just be aware with the colour it may affect it a little depending on what brandname you get it from.
The reason why I always get dehummer swtich due they are more quiet than variable speed switch or non dehummer verison will do and the last thing is make sure you leave the fan switch itself up there at high speed postion if other postion you will hear pronounced humming sound when run at lower speed mode at the wall switch.
Merci,
Marc
1 - 1 of 1 Posts
