we have a series of outlets that turn off by a single breaker, all was good. i opened a junction box in the middle of this circuit following the conduit back from a power pole(drop down raceway that has outlets at the bottom and flex coming out the top with 3 conductors).
the junction box has 3 conduit runs to it (figuring one feed and one continuing to the next box and one to the power pole) we added another power pole running the conduit to this box. to make it fit better and not put too many conductors into one wire connector I put all power pole conductors together and pigtailed those to the other conductors (blk to blk pigtailed to blk & blk same for wht & grn.
here's where it gets interesting: the old existing power pole worked just as before and tested correct for ground and neutral. the new pole was getting no power! checked all the connections to be good and checked the pole & outlet wiring all good.
finally back at a nearby panel somebody finds a breaker that has tripped and turns it back on. now the new pole works fine and tests correct. what is going on? even if I mixed up the feed and power pole conductors in the box shouldn't everything be getting power if all conductors are wired together as i describe?
ALSO the 2nd breaker that now needs to be on to get power to the new pole turns off or dims some 'always on' lighting. is there an emergency lighting wiring scheme that uses 2 circuits? (no battery or battery back up for this lighting, not true 'emergency' lighting)
