Don't know much about cars, just the basics. Was checking a family member's car the other day because it wasn't getting any heat in this cold weather. Saw that the coolant temperature gauge wasn't working. Checked the coolant levels and they were very low. No coolant in the reservoir and the radiator coolant level was low too. Coolant looked to be typical green coolant in the radiator (was hard to tell since it was dark, but pretty sure it was green) and the manual didn't specify anything except to use honda coolant but I didn't have any honda coolant so I used Peak long life coolant that is meant to compatible with all makes and models and all coolant colors
I added the coolant to the reservoir and to the radiator itself, and then turned on the car... heat finally worked and the coolant temperature gauge worked again. My family member was happy to be warm during the winter.
One month later, I come back to visit, see the coolant in the reservoir is no longer clean looking, it has turned to a very dark green color. My first thought was maybe it is just dirt and corrosion particles that accumulated inside the coolant channels in the engine and radiator where the coolant was low or nonexistent before I filled it up, and then after adding coolant it was able to collect all those particles finally and dirty up the coolant in the reservoir. My other thought is that it could be oil, maybe from a head gasket leak since the engine could have overheated from being low on coolant for so long.
Do you think it is just corrosion/rust particles from the coolant system being low for so long? Or do you think it is oil mixed in? Or could it be something else?
I don't have any pictures as of now, but wanted to get some information/advice as to what I should do next to assess and fix this situation. I am going to visit them again on the 7th and will try to do what I can to figure out what the issue is and hopefully fix it. Any advice is greatly appreciated, thank you.
