I have an old 1965 house I'm working on renovating. I've recently found a few issues to deal with.
1) One room is destined to be my office / studio where I'll be running all my computers and guitar amps. It's hooked up with a 15A breaker currently. I'd like to up that to a 20A just to make sure I've got enough draw in case all my equipment is running at once. I have the walls apart and everything is run with 12AWG two conductor wire. Is there any reason I can't just swap the 15A breaker for a 20A considering I have the proper wire gauge to support it?
2) In the same room and a few other parts of the house I have some bootleg grounds I need to fix. Since I have the walls apart, can I add an independent conductor (12AWG solid core with green sheathing) from each of the bootlegged outlets back to the junction box where proper grounds for that circuit are present? Two out of 5 outlets in the room are properly grounded but two wire conductor is run to the other side of the room from the original hookups. The two that are grounded properly have bundles of ground wire connected in one of the junction boxes before heading back to the panel.
Thanks for any input.
