1 - 8 of 8 Posts
Hi,
In other posts I have mentioned that I am re-wiring my garage. I thought I knew exaclty what I was going to do and then someone at Home Depot confused me.
First of all, all of the wire I am using is 12/2. Also, I live in New York State and the garage is detached from my house in case that matters for anything.
Basically, I was told that if I am using 12/2, and the circuit has a 20 amp breaker, I can't use 15 amp outlets. Does that sound legit?
If the 15 amp outlets are ok, I have another question. Can I use a mixture of 20 amp and 15 amp outlets on the same circuit?
Thanks.
dw1256
You can use 15 amp receptacles and you can mix 15 and 20's. I think the only time you can't use a 15 is when there is only one single receptacle for a dedicated 20 amp circuit.
while you can use 15 amp receptacles and mix them, I always like to use 20A receptacles on a 20A circuit. Reason is that you can tell by looking at the plug what the circuit is rated at. Kind of useful if/when you sell your home for prospects to easily tell that there's 20Amp service in the garage.
Licensed Electrician
You can use 15A receptacles and put the circuit on a 15A breaker.
Just a little note: A few years back it was legal to run a 12/3 and have one of the breakers a 15A and one a 20A. This might still be legal, but there might be some issues with MWBC's having to be on a 2P breaker (or handle tied).
That's a good point. I just looked at my kitchen receptacles which I know are on a 20 amp circuit and I was surprised to see that I used 15 amp receptacles. :huh:
Licensed Electrical Cont.
This was your first mistake.
DO NOT ever listen to the aisle monkeys at HD or Lowes. Sure, you'll get a knowledgeable one from time to time, but odds are it's not worth it.
E2 Electrician
Why would you be surprised? How many appliances do you own that actually have a 20 amp cord on them? And just a side note, the ONLY difference between a 15 and 20 amp receptacle is the face, the guts contain the exact same parts, so don't think a 20 amp receptacle is better grade.
Severe analness affliction :laughing:
None
I know this and I was commenting on circuit identification. I bought the supplies for the entire house in one shot which is probably why I didn't think of it. If I was only doing the counter tops or a workshop I would have bought 20 amp receptacles.
1 - 8 of 8 Posts
