I'm interested in purchasing a Mig welder rated for plug into a standard outlet of 115/120 volts.
In the fine print there's a note that says to run the machine's maximum output the branch circuit should be rated at 120 volts/25 amps/60hz. What am I missing here in this footnote? Is there such a thing as a single pole 25 amp circuit breaker?
Its confusing because the power info states to plug it into a 115/120 20 amp rate receptacle with a 20 amp breaker. Then outside the chart, it makes a statement about a 25 amp breaker. And it makes no mention of wire size within the circuit.
It also goes on to say that if an extension cord is needed it should be a minimum of 12 gauge but #10 or greater would be better. And all this comes from a quality company-Lincoln Electric. I thought I would ask here first before calling Lincoln to hear what they have to say about it. Thanks
