1 - 6 of 6 Posts
I am changing my old electric range to a new gas range. Is it permissible to use the heavy existing 220v wiring to the old electric range for powering a new gas range that requires 120v?
My intent is to unhook the existing wire from its 50 amp breaker and run it to a 20 amp breaker, using the red as the ground (and clearly identifying it as such).
I also intend, of course, to install a 20 amp receptacle in place of the old 220v range receptacle.
If this is acceptable it will greatly simplify the wiring requirement for the new range and still leave the old wiring available for an all electric range in the future.
· A "Handy Husband"
What color and how many wires are in the existing cable? It is not code compliant to remark a red wire as ground (and I assume you mean neutral)
Thanks for the info guys
:thumbsup: Upon re-examining the existing wire I've found that it is a 4 wire cable - red, black, white, and a bare ground. I believe I'll be able to use this for my 20 amp 120v circuit now.
Will save me a lot of headache!
1 - 6 of 6 Posts
