Hi,
Recently ran some 12/2 wire for a dedicated 20a circuit from the basement to the attic, up past the cold air return. This is also where the hot and cold water pipes go from the basement to the second floor.
There's a possibility that my 12/2 wire is resting up against the copper hot water pipe.
(I took a picture, but the contact point is 5' away, difficult to determine from the picture alone, and this is in a spot where no man's head will fit, only my arm
Q:
What would happen if the 12/2 casing melted, and further melted through to the hot wire casing:
Would it ground out and trip the breaker?
*** Would it electricute someone if they were having a shower and the hot wire touched the copper pipe?
OR, have I asked a very stupid question?
AND is it impossible for the 12/2 casing to melt from something only as hot as my hot water pipes? (Note: my hot water tank is turned up to max temp)
Thanks again!
Q:
Thanks again!
