1 - 8 of 8 Posts
Is there any benefit to running 12/2 for everything? I bought a house and it seems a lot of the wiring is 12/2. Should I stick with the 12 gauge when extending to some new recessed lighting I am installing or should I jump off the existing 12 with 14 gauge (is that even legal?)?
Any help is much appeciated
" Euro " electrician
Stay what the conductor size is allready run so if you have 4.0mm² { #12 AWG } so stay with it and they will work fine with 20 amp breaker however a nice gotcha yeah you can use 15 amp breaker as well but normally I resved that for long runs only.
Do not use 2.5mm² {#14 AWG } with 4.0mm² there due they are only rated at 15 amp max.
Merci.
Marc
Reactions: Proby
Electrician
Yup, you can't run #14 wire on a 20A circuit, even if it's only for one light.
As for running all #12, I have been doing that more and more lately.
Yep you can use 15 amp breaker with 4.0mm² cable that is not a issue at all but just make a note on the breaker box what that goes.
Merci.
Marc
"Is there any benefit to running 12/2 for everything?" - you only have to keep track of one wire size for all branch ckt's, except for dedicated loads of course.
Licensed Electrical Cont.
Sorry should have mentioned tn this case, the circuit is 15amp. Is it still ok to use 12 with a 15amp?
Yes, but under normal circumstances (such as not extremely long circuits) it make NO sense to use #12 on a 15A breaker. If it is all #12 use a 20A breaker.
Reactions: frenchelectrican
1 - 8 of 8 Posts
