I have a 220v line that runs to the end of a dock (it runs a boat lift). I would like to put a 110v light out there as well. Can I take one leg of the 220v and use it to run the 110v light? The boat lift and the light will not be on at the same time.
Thanks,
· Lic Electrical Inspector
Thanks,
The light needs a neutral (white wire).
· Semi-Pro Electro-Geek
Thanks,
You can only do this if it's a 4-wire circuit, i.e. there's a neutral wire present. Otherwise no. If there is no neutral, then you have two options for installing a light: either use a small transformer to step 240V down to 120 to run the light, or use a 240V light. If you use a fluorescent, metal halide, or sodium fixture, you can easily choose one with a 240V ballast. That's the simplest solution.
· Electrical Contractor
I'd opt for a small control transformer for the light. Using an LED or CFL light would not need many watts, and something as small as a 40VA control transformer would be sufficient for such a light.
· " Euro " electrician
I was going to suggest that one as well but that work very well.
Merci,
Marc
